Hello everybody, I need some suggestion on powered subwoofers> My budget its $1000.00 and i need it for venues from 200 to 400 people. Thanks.
Posted Fri 06 Sep 13 @ 10:34 pm
Look at the QSC KW 118. It's in your budget range if you get a re-manufactured one. Normally they are $1399. I'm ordering one next week to match my new KW 122's. It's a nice unit.
Posted Sat 07 Sep 13 @ 1:33 am
You can Use Two 15 inch speakers & One Powered sub. Since your budget is 1,000 This subwoofer is good enough and its less than 1K.
http://www.guitarcenter.com/Harbinger-1000W-Subwoofer-with-BBE-processing-107928681-i2524855.gc $749
http://www.musiciansfriend.com/pro-audio/harbinger-1000w-subwoofer-with-bbe-processing $699
I heard The 700 watt sub and it kicks. The New 1K watt sub must sound nicer since it has a BBE maximize built plus more power.
Posted Sat 07 Sep 13 @ 3:11 am
http://www.guitarcenter.com/Cerwin-Vega-CVA-118-18--Active-Subwoofer-104607841-i1380539.gc
i am very partial to bose and cerwin vega bose models will be expensive
for 400 people u need a substantial system as u know......
not convinced 1 sub is enough but it's a start better than zero subs
Posted Sat 07 Sep 13 @ 9:01 am
I play 200 to 300 people often with my QSC KW181. Pretty pleased, not maxed out either. Highly recommended if you can get it remanufactured or streatch a bit.
Posted Sat 07 Sep 13 @ 9:20 am
I Dj yed for the Military (400 +) guest and My setup was Two Jbl Prx615m speakers and One Qsc Kw181 sub. The system was loud enough. I was thinking about buying another KW181 but, I think what I have is good for now.
Posted Sat 07 Sep 13 @ 10:47 am
Respectfully, Chuck, I disagree. I have one of these and it full on ROCKS! I'm not a fan of Peavey per say. They don't sound very clean. Their mid and high end lack punch and clarity. That being said. My sub has carried 600 people at a wedding reception that was invaded by a second reception who's DJ didn't show up. I thought I was in trouble wattage wise. That sub of mine had dust falling OFF THE CEILING of the venue. Later, I had a pro sound engineer I know walk up and ask WTF was I using? (the label fell of the front years ago). Even he was impressed and, he's done national touring sound for 20 years.
Posted Sat 07 Sep 13 @ 11:23 am
i see your point Tear but I've done some big rooms that were really bad acoustically and that was kinda what i had in mind
in a highly reflective room with barefloors or walls it can be very loud even with a small system
that Peavey has a useable low of 27 hz wow
Posted Sun 08 Sep 13 @ 7:24 am
It's a beast dude....
Posted Sun 08 Sep 13 @ 9:06 am
Hello everyone, I have an Alto 18" powered speaker and I have to say I am pretty impressed with it so far. I have done gigs for 350 people. Now I am speaking from a mobile Dj aspect. You don't need to kill people with bass at a wedding or most mobile gigs. In a club it would be a different story.
Posted Sun 08 Sep 13 @ 12:27 pm
ya know Tear .....
that was very muted and polite your reaction to my post....
this is one of those opinion laden topics where everyone and no one is right.....
i was expecting someone to get all aerated and vexed by now.......i feel kinda cheated, don't you ?
anywhoo..... i used to do some pretty big bar mitzvahs and usually with 2 big beat up subs .......
sometimes no room , so the subs were just together in there spot , sometimes had the luxury of spreading them out
Posted Sun 08 Sep 13 @ 6:56 pm
Sorry to let you down Chuckles. Want me to argue with you a little bit? Would that help?
Posted Mon 09 Sep 13 @ 11:10 am
While we're on the subject of Subs, anybody have or used the new Mackie DLM12S 2000 What? I mean Watts output on a 12" speaker!!!, small, 48lbs. man this looks good for small venues..., but need some real life input...
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=887912&is=REG&Q=&A=details
Posted Mon 09 Sep 13 @ 1:41 pm
HK Audio Elements. Using the Dual 10" at 1250 watts.
Posted Mon 09 Sep 13 @ 4:51 pm
