Topic: Laptop Volume question
When using a controller I obviously would need to turn the volume on the laptop off correct?
I know its a dumb question but I am just wanting to double check
Posted Sat 24 Aug 13 @ 11:01 am
It won't matter, if you are using an external sound card then all sound will be routed there and the laptop's internal card just won't be used.
Keith
Cool thanks for the help
