I have a Numark Mixtrack Pro....I have VDJ Pro Full.....Finally I can control volume controls, crossfader, load music in the decks etc
Here is my problem when I press play on the controller I get nothing....The controller is all lit up buttons flashing like its suppose to but it won't the music
Help please!
Help please!
Posted Wed 21 Aug 13 @ 10:38 pm
Download the audio drivers from Numark http://www.numark.com/support/downloads
Also download the mapper https://virtualdj.com/addons/15711/Numark_MixTrack_PRO_II.html
Posted Wed 21 Aug 13 @ 11:04 pm
When I go to the numark it only gives me an LE update
Posted Wed 21 Aug 13 @ 11:14 pm
I know this will sound like the universal fix technique... But have you unplugged it and plugged it in again? It works for me when it doesn't play sometimes. Good luck!
Posted Wed 21 Aug 13 @ 11:19 pm
Yep I've done that a couple of times then it would either work on both sides for a little while or it would just work on one side or not at all
Posted Wed 21 Aug 13 @ 11:21 pm
Please make sure your Mixtrack isn't set as standard audio device in your OS.
Posted Thu 22 Aug 13 @ 4:56 am
reinstall the driver and reset the mapping...
Posted Thu 22 Aug 13 @ 7:15 am
There is no driver for the Mixtrack Pro. It's a class compliant audio interface. It doesn't need a driver.
Posted Thu 22 Aug 13 @ 7:27 am
The most common reason for a 'play' button not to work is an incorrect sound configuration. What is your sound setup in 'config' set to?
Posted Thu 22 Aug 13 @ 10:17 am
Just a thought - have you tried it in both vinyl and CD modes?
Sometimes, if I'm wearing the wrong trousers, or wrong socks, or whatever, a static charge builds up which renders my jog wheels useless. The music plays when I touch the jogwheel, and stops when I take my hand away.
The only fix is to earth somewhere, or play in CD mode, which is ok, but not what I prefer.
Last resort - try taking your shoes and socks off..?
Crazy, yes, but also true.
Ta
Mike.
Ta
Mike.
Posted Thu 22 Aug 13 @ 4:54 pm
Sound setup is Input: None......Output: Headphones (Master Chan 1&2 Headphones Chan 3&4) and the sound card is set on Numark
Posted Thu 22 Aug 13 @ 7:10 pm
Change everything!
I have mine set to Advanced, with ch 1&2 being master output, and 3&4 to headphones.
Ta
Mike.
Ta
Mike.
Posted Fri 23 Aug 13 @ 12:20 am
please my eyes r burnin' .....put yer shoes back on
Posted Fri 23 Aug 13 @ 4:34 pm
ok , go into the sound card and set the tab to advance and then select the controller and 1-2 is the sound and 3-4 is the head phones . click apply and then ok
Posted Fri 23 Aug 13 @ 9:43 pm
