I'm just in the process of copying all my music files over to my laptop - is it possible to also copy the VDJ Library over as well to include all the BPM's etc etc to save me having to analyse the files again?
Thanks Paul
Thanks Paul
Posted Sat 17 Aug 13 @ 8:07 am
yes you can... just copy the database and paste it in your laptop, if your directories change in any way you will need to open the xml file in notepad/wordpad and use find and replace "ctrl + h" to change the location of your music within the xml. The database is located here on PC
C:\Users\yourName\Documents\VirtualDJ/VirtualDJ Database v6.xml
Posted Sat 17 Aug 13 @ 8:38 am
brill ! many thanks for a very quick reply !
Posted Sat 17 Aug 13 @ 8:49 am
