I'm doing some live remixing using Hot Cues and my button-press timing isn't quite as sharp as it could be (there's a reason I'm not a drummer ;-)). Is there a Virtual DJ equivalent to the Quantized Hot Cue feature that the Pioneer CDJ-2000nexus has (or, if not natively available, can I somehow script it with VDJScript)?
Posted Tue 13 Aug 13 @ 4:43 am
just activate smart_cue, there is a lock on the default skin near to the cues... or you can of coarse map something like this to a button or your keyboard or the ONINIT of your controller or skin.
deck 1 smart_cue 1 & deck 2 smart_cue 1 & get decks 4 ? deck 3 smart_cue 1 & deck 4 smart_cue 1 & : nothing
bare in mind that if you activate smart cue you won't be able to rapidly hit the hot cues.
Posted Tue 13 Aug 13 @ 5:27 am
Ah! Great! I was sure that if it was on a CDJ that it must also be in VDJ! Thanks! :-)
Posted Tue 13 Aug 13 @ 7:11 am
