Just started DJing and producing. But wondering if anyone could give me some assistance with some of my issues:
- The Beat Map on my 7.0.5 version of the demo isn't coming up properly, instead of being spread out it which will help with beat matching it is all scrambled together.
- Another problem I have is that when I load certain songs, mostly my house beats the song beat length doesn't appear so I cant fast forward the track.
Any help would be great...
Posted Fri 09 Aug 13 @ 5:15 pm
Go into Config>Performance: Here towards the bottom you will see Max Load. There you set Max length(time) of the tracks to load on deck. If tracks are longer than the max, they will load the way you are describing.
Posted Fri 09 Aug 13 @ 5:33 pm
