Topic: Virtual DJ LE and Numark Mixtrack pRO
Can I use the Virtual DJ LE with a Numark Mixtrack Pro controller? the virtual DJ full version is a little pricey especially since the Numark comes with Serato. But I would like to continue using VDJ due to content subscription.
Posted Tue 30 Jul 13 @ 8:50 pm
If youre mixtrack came with VDJ Le then register it to youre profile, and yes you can still use it with ContentUnlimited.
https://virtualdj.com/users/edit.html
If it didnt come with an LE version then the only way to use the controller is by purchasing VDJ Pro Full.
Oops..just noticed you said it didnt come with VDJ. Then the only way is with Pro.
