Just a quick simple midi test. But could be fun if completely mapped :)
Posted Tue 23 Jul 13 @ 2:43 pm
That's awesome. What was sensing your hand motions?
Posted Tue 23 Jul 13 @ 2:50 pm
The device is called leap motion.
http://www.leapmotion.com
Posted Tue 23 Jul 13 @ 3:07 pm
PachN wrote :
Wow! I thought it would be over $100! Only $80 is not bad at all. Thanks for the link.
Posted Tue 23 Jul 13 @ 3:11 pm
They are also available at Best Buy.
Posted Tue 23 Jul 13 @ 3:14 pm
I just got mine and Im still setting it up, havent started looking into it, how did you map that movement?
Posted Tue 30 Jul 13 @ 11:53 am
I have one on order as well. Should be arriving any day now. Can't wait to try it out :)
Posted Tue 30 Jul 13 @ 7:30 pm
I downloaded the programm "Geco" from airspace store and followed the tutorial on this site.
http://www.uwyn.com/geco/tutorials/
The rest was simplemidi mapping in VDJ.
Yeah, it's really fun to play around with it. But I think they need to improve the recognition rate. It's sometimes a little bit stuttering and your hand movements are not recognised correct. Maybe that could be fixed with a firmware update. Or the apps I tested need improvements.
Posted Wed 31 Jul 13 @ 3:20 am
