Hey all!
Quick question regarding external (sound) cards!
I'm currently using the Maya 44 USB card for time coding with my CDJ 200s; however, the latency and response lag is not very friendly. Can anyone recommend other sound cards with significantly better performance?
Thanks in advance!
Thanks in advance!
Posted Fri 12 Jul 13 @ 2:49 pm
I've had Hercules, a Native Instruments Audio 4, the internal soundcard in my Denon DNX1600 and a Serato SL2. I can tell ya the best performing for my taste is the Serato SL2 box.
Posted Fri 12 Jul 13 @ 3:18 pm
M-Audio Conectiv - ran it at 1ms.
-David
-David
Posted Fri 12 Jul 13 @ 7:41 pm
Make sure that your computer has been optimised for DJ performance:
https://virtualdj.com/wiki/Performance%20Issues.html
Once optimised, this will enable you to set lower latency for a better response without sound break-up.
Posted Sun 14 Jul 13 @ 11:30 am
