Hi guys!
I would ask if anyone has ever used "JVC ADIXXION" camera as a "simple WI-FI web-cam."
Is it possibile using it with "CAMERA" plug-in of VirtualDj?
if not, can you give me some good and cheap alternative?
thanks in advance!
thanks in advance!
Posted Tue 09 Jul 13 @ 9:21 am
You will need a video capture device, in order to use any camera. ION, and Dazzle offer some options.
Posted Tue 09 Jul 13 @ 11:29 am
Can you give exact model ?
I need a wi-fi soluzion....no cable.
Thanks!
Thanks!
Posted Tue 09 Jul 13 @ 12:36 pm
If the unit is seen by Windows as a webcam, then it should work with the camera plugin. Another option is the Essential Media plugin which allows for camera input also.
If you do decide to go with a wired video capture device, then I can tell you that the "Hauppauge USB-Live-2" works very well with both of the afore mentioned plugins too.
Posted Tue 09 Jul 13 @ 3:08 pm
Ok....but... if I buy a video capture device i'll need also a wi-fi transmitter/receiver.
In the past i tried "easycap" and I still own it, but the problem is that the frame rate is not satisfactory.
I want a system with a good framerate and has a good night vision ....
Maybe I ask too much ... : (
Posted Wed 10 Jul 13 @ 4:56 am
