what is the best sound config for using macbook pro and ddjsx? i will be using the mic as well if that makes a difference. any help is greatly appreciated
Posted Tue 09 Jul 13 @ 12:43 am
I didn't have to do anything special on mine. Plugged and played.
Posted Wed 10 Jul 13 @ 3:32 am
im speaking of the vdj sound config. how do you have it set? input / output / sound card etc
Posted Wed 10 Jul 13 @ 7:06 am
Pardon the late reply.
Under 'sound setup' in VDJ Config I choose 'Outputs - Advanced Output'
And then under the 'Advanced Config' pane I choose Master - Pioneer DDJ-SX - outputs 1&2
And 'headphones - DDJ-SX - outputs 3&4'.
Hope that helps in some way.
Ciao.
Ciao.
Posted Sat 13 Jul 13 @ 6:57 pm
The ADV config isn't needed ;-)
Input - None
Output - Headphone
Soundcard - ASIO or 4Out for Mac ---> beside select the SX as the soundcard!
Thats it!
Input - None
Output - Headphone
Thats it!
Posted Sun 14 Jul 13 @ 3:55 am
Hmmm, now that I think about it, my config is actually a leftover from my old NS6.
Perhaps it wasn't even necessary then, but its always worked well.
Posted Sun 14 Jul 13 @ 5:03 pm
thanks...i see there are different opinions. separate question....preferred skin that helps in using all or most of features???
Posted Tue 16 Jul 13 @ 6:24 am
I'm on the SX skin personally. Prefer the small "battle mode" view as them more of the track list can be seen.
https://virtualdj.com/addons/15773/Pioneer_DDJ-SX.html
https://virtualdj.com/addons/15900/Pioneer_DDJ-SX_HD.html
Posted Tue 16 Jul 13 @ 7:23 am
