Telika H Epityxia den irthe , kai toso............
Kapoia kollimata ston ixo eginan kai pali.
Pame gia backup ,format , k.l.p kai vlepoume........
Posted Tue 16 Jul 13 @ 12:15 pm
Mpikan ta 7aria , pleon katharotato to laptop , kai mexri stigmis dpc latency mono prasina.......alla oi dokimes tha synexistoun...........
Posted Wed 17 Jul 13 @ 6:59 am
Auto einai euxaristo.
Sto Hp Gianni ?
Sto Hp Gianni ?
Posted Wed 17 Jul 13 @ 7:53 am
Sto Hp Gianni ?
Sto Hp Gianni ?
Nai ston HP , kai den exo valei oute antivirus mesa katholou kai leo kai na min valo.
Ta prasina mou ftanoun peripou to poly sta 700ms....(Kalo H kako?) me peripou konta 1 ora na doulevei H dpc latency
Kitrina kai fysika kokkina katholou!!!!
Apla prepei na ksanavalo tin karta kai ton controller epano , kai na dokimaso me mousiki.
Pantos me kleisto to virtual , kai me optimized , alla me to kalodio ethernet epano , eimai sta proanaferomena.
Posted Wed 17 Jul 13 @ 8:19 am
tweakare ki allo to pc egw eimai 70-170μs
Posted Wed 17 Jul 13 @ 7:14 pm
Tha koitakso na do ti alles rythmiseis mporoun na ginoun , alla nomizo oti kai sta proanaferomena , eimai entaksei.
An bebaia to petyxo ki allo kato , kalo tha einai.
Posted Thu 18 Jul 13 @ 4:29 am
Kainourgies epipleon rythmiseis , kai xoris Ethernet kalodio epano ,
mexri 370ms peripou prasina.
To katevasa sto miso apo extes , ti allo piaaaa??????
(Me optimizer , me kleisto virtual , xoris katholou antivirus k.l.p)
Posted Thu 18 Jul 13 @ 6:27 am
gia hp 370 max kala einai
Posted Fri 19 Jul 13 @ 8:27 am
Telika me paaaara poly agxos , kai agonia , to SK , vgike anodyna , me peripou sta 600ms maximoum , xoris kamia diakopi , k.l.p
Ola prasina , alla eipame peripou 600ms
Alla ki alloi mou exoun pei gia HP , pali kala.
Tespa tha deiksei allo ena test tha to perasei thelei den thelei , to PSK , pou erxetai , kai thelo na pisteyo kai pali anodina.
Posted Sun 21 Jul 13 @ 3:37 pm
Tora pou to anoiksa spiti , peripou gia kamia ora , gia mia anasygkrotisi , katharisma , k.l.p , gia na einai etoimo to vrady , kai me tin vasi tou me tous anemistires , otan to ekleisa , meta , diapistosa , na einai zesto , oxi apo kato , alla pianontas to apo tin ekso meria , sto kato meros tis othonis , dekskia , apo tin antitheti pleyra pou einai to anemistiraki apo kato.
Den ksero ti na po , isos na symbainei kai na min to eixa proseksei........
Tespa , as tin vgaloume kai ayto to SK , kathari
(to deytero stin seira , apo tote pou mpikan ta 7aria , kai egine ksekatharisma k.l.p) ,
kai meta tha tou exo pali perissoteri (oxi apolyti) empistosini.
Posted Sat 27 Jul 13 @ 4:32 am
εκεί που πονάνε τα laptops είναι στην ψύξη τους όταν παλιώσουν με το καιρό πιάνουν ανάμεσα στις θυρίδες της ψήκτρας και του ανεμιστήρα βρόμα (χνούδι) με αποτέλεσμα να φράζουν οι δίοδοι του αέρα και να μην ψύχεται καλά .
το τελευταίο καιρό στο λαπτοπ μου άκουγα τον ανεμιστήρα να δουλεύει συνέχεια και να ζεσταίνετε πολύ και μια δυο φορές που δεν το είχα πάνω σε βάση (με ανεμιστήρες) έκλεισε. ανοίγοντας το καπάκι και απομακρύνοντας το χνούδι από την ψήκτρα και ο ανεμιστήρας δεν δουλεύει συχνά και το λαπτοπ δεν είναι ζεστό!!
Posted Sat 27 Jul 13 @ 5:09 am
Ayta ola , me to thema psiksis , einai apo ta PROTA PROTA , pou eginan , sto laptop , kai meta vima vima ta ypoloipa......
Alla kai fysika eyxaristo poly pantos.
Tespa , thelo na pistevo oti ola tha pane kala...............
Posted Sat 27 Jul 13 @ 6:04 am
Μαλλον τελικα , παμε καλα.
Και αυτο το ΣΚ , πηγανε ολα καλα , φυσικα παντα , κοντα , στα 570ms , πρασινα μονο!!
Η Maya , ξαναρυθμιστηκε , στο Normal , απο , relaxing normal , και εν πασει περιπτωση , συνεχιζουμε καλα......
Το optimize , κανει ΠΟΛΥ καλη δουλεια , οταν το δουλευεις σαν διαχειριστης.
Και πιο πολυ το διαπιστωσα , οχι μονο στον HP , φυσικα , που εχει στηθει ξανα απο την αρχη , αλλα ειδικοτερα , στον Toshiba , που δεν εχει , γινει καμια ρυθμιση απολυτως , και το optimizer , τα εχει περιπου , στα 300ms , στα πρασινα.Φυσικα ηταν ανοιχτο το Virtual DJ , αλλα δεν δουλευε , γιατι ο Toshiba , ειναι το backup μου , και δεν ειχε την Maya , συνδεμενη , αλλα τα USB του μικτη.
Αυτα.....
Τωρα ξανα νεωτερα , απο τελος Αυγουστου , που ξαναρχιζουν οι εκδηλωσεις.
Καλο Καλοκαιρι , καλες διακοπες!!!
Αυτα.....
Posted Mon 29 Jul 13 @ 5:28 pm
Επαναφερω το θεμα , απο τις πισω.....σελιδες , γιατι ειχαμε και παλι προβλημα.
Ειχα ανεβοκατεβασμα στην ενταση του ηχου , ξαφνικα , και αποτομα , και δεν ειναι απο το LapTop.
Ειδικα μετα απο οσα εγιναν στο LapTop , και..............απο εμενα.....................και απο αλλον.............(ξερει)
Πολυ φοβαμαι οτι ηταν απο την καρτα ηχου , την maya44 usb.
Οταν το εκανε αυτο το LapTop , δεν εδειχνε απολυτως κανενα προβλημα , ημουν στα πρασινα , κοντα στα 650ms , και γενικα , δεν μου εδειξε κατι το LapTop , η το προγραμμα , οτι εχει θεμα.....
Εχω Αρχισει και σκεφτομαι σοβαρα την λυση της κονσολας , αλλα , ειναι και θεμα οικονομικο , αυτην την περιοδο.
Στην maya εχω τους παλιους drivers , σκεφτομαι να βαλω τους τελευταιους , αλλα δεν μπορω να το διακινδυνεψω Live.
Οποτε μεχρι να βρω το προβλημα , ειμαι σε αργια δυστυχως......................
Βεβαια παιζει να φταιει και ο μικτης , αλλα σε ολα τα ποντεσιομετρα ? , γιατι τα αλλαξα τα rca , μεχρι και το μαστερ , αλλαξα , και επαιξα με το zone , αλλα τα ιδια και παλι ανεβοκατεβασμα στην ενταση.
Και το πλεον , τρελλο , ειναι οτι το εκανε μαλλον , (δεν ειμαι απολυτα σιγουρος πανω στον πανικο) , και στο αλλο LapTop , που ηταν συνδεμενο με τα usb , του μικτη...........τρελλοοο
Δεν ξερω τι να κανω πλεον , και δεν παιζω , μεχρι να βρω λυση , φυσικα , γιατι δεν λεει να γυρνανε 300 ατομα , να σε κοιτανε........
Posted Mon 30 Sep 13 @ 2:50 pm
Ena kalos katharismos tou mikti isws lysei to provlima. Otan eidika paizeis se ekswterikous xwrous, me skoni klp, epivaletai mia tetoia diadikasia arketa syxna. Sto ekane kai ta dyo decks ?
Posted Mon 30 Sep 13 @ 4:49 pm
Πέρα από τα γνωστά σπρέι, έχεις να προτείνεις τίποτε άλλο για καθαρισμό του μίκτη ?
Posted Tue 01 Oct 13 @ 1:30 am
Katanow plirws tin "mastoria" tou Ellina, proswpika omws otan prokeitai gia epaggalmatiko eksoplismo, apeuthynomai se epaggelmaties. Ena ilektronikos, kserei ti akrivws prepei na katharisei kai pws. Tha testarei episis, epafes, pontesiometra klp. To na kathariseis mia syskeui me pepiesmeno aera kai kapoio sprey, mporei na dwsei lysi, omws mporei na einai proswrini kai na min odigisei se ousiastiki lysi tou provlimatos.
Posted Tue 01 Oct 13 @ 6:14 am
Akrivos ayto , eixe ginei kathrismos tou mikti , me aera , apla , kai na pou egine ayto pou egine.
Nai kai sta 2 plato to ekane Mpampi , gi'ayto den eimai apolyta sigouros to ti mporei ma ftaiei.......
Posted Wed 02 Oct 13 @ 3:11 pm
kalipsera exw agorasei to xdj-r1 kai to douleuw me to virtual to pro full kai ekei pou paizw polles fores me kolaei kai arketes fores me leei h konsolla ekei pou paizw not connected kai xanete den leitourgei tpt
ti kanw??
ti kanw??
Posted Sat 05 Oct 13 @ 12:51 pm
