I am having an issue with my VDJ software, I deleted all my playlists and did a clean, Fix , Check of all my songs and everything seems to be working correctly. Now my problem is now when I play a song on either deck the waveform on the top of the deck moves about 700 miles an hour. Doesn't matter if the BPM is 88 or 135 the waveform is moving extremely fast. Is there something that I have done to cause this and how can I fix this.
Thanks
Derek
Thanks
Derek
Posted Sat 06 Jul 13 @ 10:20 am
select a song that gave you problem, then re-scan it (BPM, right click) and try it out.
Posted Sat 06 Jul 13 @ 11:19 am
My guess is you zoomed it in. Solution: zoom it out!
Posted Sat 06 Jul 13 @ 11:26 am
Thanks for the reply. Your solution worked. I had never zoomed in or out before so I didn't know you could do that. I thought maybe I had to rescan all my songs for their BPM.
Thanks Again Much Appreciated.
Posted Sat 06 Jul 13 @ 11:48 am
