Good morning,
I recently purchased a Hercules rmx controller and came across a problem but I can not indetificar if the problem is in the controller or the software my pre-listening just one hour to another totally ruined this squeaking total distortion as if my phone was blown up anyone ever had this problem? takes a lot of pre-listening'm newbie and already tried several procedures and until the present time solved nothing if someone can help me I will be grateful.
Posted Fri 05 Jul 13 @ 11:59 pm
Have you tried downloading the latest drivers from the Hercules website? The drivers that come with the installation disc are very old.
Posted Sat 06 Jul 13 @ 12:30 am
good I'll try this solution, I will reinstall everything boot all the virtual dj, clean up the hercules, and I'll try one more time, one thing that is driving me a foot behind is because I was working two days ago and just started distorts and that worsens the situation of confusion is that the rear output outputs are working perfectly.
Posted Sat 06 Jul 13 @ 1:51 am
Also, make sure that your computer has been optimised for DJ performance: https://virtualdj.com/wiki/Performance%20Issues.html
Posted Sun 07 Jul 13 @ 11:56 am
If you still have issues post and I will help you through it...
Posted Mon 08 Jul 13 @ 12:28 am
