I have searched and have not found a solution to my problem. It is mapped fine but scratching and cueing sounds extremely digital and the platers are off. I attempted to adjust sensitivity but it is not working. Does anybody have a cut and dry for this?
Posted Thu 27 Jun 13 @ 9:59 pm
You need to give details of your computer & os first, then you also have to tweak your computer by turniing off services you don't need.. like wifi.
Posted Fri 28 Jun 13 @ 12:05 am
I have MacBook Pro 2009
Software OS X 10.8.4
2.66 GHz Intel Croe 2 Duo
4GB 1067MHz DDR3Graphics
NVIDIA GeForce 9400M 256 MB
Everything works fine with Serato.
VDJ worked perfect with Denon MC3000
Posted Fri 28 Jun 13 @ 4:50 pm
Delete the slicer portion of the mapper and the LED_Volume. I had the same problem. Their working on a fix, but I haven't heard anything in from them in a while. After those parts are deleted everything else works great. If deleting those parts does not fix your issue, then you may have a different problem. I don't think every ddjsx/computer has the issue.
Posted Fri 28 Jun 13 @ 8:50 pm
Will try that now!
Posted Sun 30 Jun 13 @ 10:19 am
Have to have a 4 deck skin too.
Posted Sun 30 Jun 13 @ 11:45 am
Latency has gotten a little better but still a little digital. Removed the slicer commands and led_volume. Also I have 4 deck skins. Let me know what I can do to improve the sound. Vdj worked fine with my denon mc3000.
Posted Sun 30 Jun 13 @ 9:06 pm
This is working for me. I use PureScratch when I'm not going to be do major tempo changes.
Posted Sun 30 Jun 13 @ 9:34 pm
I've been told to run it at 16bit.
Posted Mon 01 Jul 13 @ 12:34 pm
Changed up the settings. I am not sure where to change it from 24 to 16 bit due to running a Mac.
Posted Mon 01 Jul 13 @ 9:39 pm
Not at all familiar with macs. Isn't there a way to access your sound card via pioneers driver? Being that its a mac should def try the default map after the problem is resolved though. Haven't heard anyone having my issue on a mac.
http://youtu.be/Rhq8Rm1a8K4
Posted Mon 01 Jul 13 @ 10:21 pm
