Hello does anyone know how to map and which skin to use?
Posted Fri 24 May 13 @ 5:19 pm
The NI S4 is not natively supported but you can try this mapper https://virtualdj.com/addons/14443/Traktor_Kontrol_S4.html
Currently there is no skin that will look identical to your controller, and the skin is not affecting the operation of the controller at all. You can choose to use the Default one or any of the available in our Download Pages depending on the custom mapper above .. https://virtualdj.com/addons/skins.html?category=all
Posted Fri 24 May 13 @ 6:06 pm
