Topic: Virtual DJ Pro and LE same machine?
Is this a good idea?
Do they share anything beyone maybe the same xml data base?
Could I copy skins over to it and plug ins?
Would I gain anything?
Don't hate, just curious.. :)
Posted Fri 17 May 13 @ 1:01 pm
No point installing LE if you have Pro.
You can install separately and use the same database but it can get a bit messy. You can't configure sound setup or skins in LE.
Just use Pro and if you have more than one config for separate controllers etc. you can use Scott's profile switcher.
https://virtualdj.com/addons/12300/SBDJ_Profile_Switcher.html
I wouldn't do it personally as there's no gain.
Keith
Past few years I have had my LE, Broadcaster and Pro all in one same laptop with no problems...
