I have posted in here before with no assistance. I just switched to MAC from PC and i'm having serious problems getting all three components to work properly. I installed the lastest VDJ, and the latest firmware on the NS6. When i open VDJ none of the settings work, i go into configuration and basically have to the master to channel, and then it will play, sometimes it wont, i have to reboot disconnect and reconnect the device...
So i did a fund raiser last night and had songs auto playing while they did a tricky tray. When i went back to the booth to start the dance music, i had nothing. Volume didnt work, nothing, if one deck was playing and i moved a song to another deck it would switch to that deck, then i would have to hit the headphone button to get back to the first track. then to play the second track i would have to click on that decks headphone button. I had to to stop and switch laptops in the middle of the gig, that sucked.
So as of right now there is no way i can use my MAC with VDJ and NS6, can someone please try and assist me with this problem?
Thanks in advance..
Pete
Thanks in advance..
Pete
Posted Sat 11 May 13 @ 7:15 am
after trying additional things, when i go in VDJ i have to goto Config, click on performance and it will start playing, but after a few hours it loses all connection to the NS6? Any ideas? Anyone?
Posted Sat 11 May 13 @ 12:14 pm
wow, nothing. I guess i found a new issue..
Posted Sun 12 May 13 @ 7:27 am
