Hello! Im new to this community and just had a couple questions about my setup that i cant seem to get working.
Set-Up:
im running two ION ITT03A Turn Tables that are connected to an ION IMX02 usb computer mixer. From the mixer i have my RCA to 3.5mm output connected to my speaker input. Each turn table has a virtual dj timecoded vinyl on it. As far as software goes, Im running virtual DJ pro full.
I have my sound configuration settings as follows:
Inputs: set to timecodes
Outputs: set to external mixer
Ive tried messing wit the time code settings but i still cant seem to get virtual dj to recognize the vinyls. it just wont pick them up. is there a setting that i need to apply? can anyone help?
Set-Up:
Posted Wed 08 May 13 @ 1:27 am
Hello,
which version of Virtual DJ are you using exactely ? (7.??)
As far as i see the mixer does not have stereo Phono inputs that get routed to the Computer - so this setup will never work.
Greets, Heiko
Greets, Heiko
Posted Wed 08 May 13 @ 1:46 am
im running 7.4 currently
the mixer does have phono lines..but to be honest i have no idea what those do or why i need them? or how they will get routed to the computer.
also i have a macbook pro if that helps at all.
i appreciate the response!
Posted Wed 08 May 13 @ 1:54 am
To use Timecode you need a Soundcard with 2 stereo Phono inputs to connect your Turntables to.
Your mixer just offers 2 stereo connectors to use normal Vinyls with the mixer - this is not wrking for Timecode because this are not Soundcard input channels that get routed to your Computer.
Greets, Heiko
Greets, Heiko
Posted Wed 08 May 13 @ 1:59 am
looking at the mixer, i have:
line 1 rca input & phono 1 input
line 2 rca input & phono 2 input
two usb inputs
main rca output
i currently have my inputs in line 1 and line 2. phono 1&2 inputs are empty
two usb inputs
main rca output
Posted Wed 08 May 13 @ 2:03 am
tried plugging my outputs from the turntables into the phono inputs. im getting audio out of my speakers and can hear my scratching. but still no songs. VDJ still not reading the vinyls. any suggestions?
thanks,
CT
thanks,
CT
Posted Wed 08 May 13 @ 2:22 am
The USB in this mixer is for output only (I.e: Mouse/keyboard or MIDI controller user.) Plugging turntables into the phono inputs of the mixer will allow you to use them as traditional vinyl decks only for playing normal vinyl records without a computer.
To be able to use timecode, you will need a suitable ASIO capable sound card with at least 4 inputs (2 stereo) and 4 outputs, such as ESI Maya44 USB. Please read our FAQ pages:
https://virtualdj.com/wiki/Timecode%20Requirements.html
https://virtualdj.com/wiki/How%20do%20I%20configure%20my%20timecode.html
Please also register your Pro serial number to your account https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.)
Posted Wed 08 May 13 @ 5:57 am
