I need help please!!! i have 2 PA speakers connected with a numark IO interface. Im using Virtual DJ LE. I just bought a powered subwoofer for bass. I already try to connected to one of the PA speakers but I can't make it work. can you please help me what I need to do or if I need something else.
thank you for all your help.
Ed
Ed
Posted Mon 06 May 13 @ 9:04 pm
I think you might need to upgrade to use sound card. Have you used the sound card before?
Posted Mon 06 May 13 @ 9:14 pm
Are these pa speakers powered? You say you are using LE, what controller do you have, and why didn't you register the software?
Posted Mon 06 May 13 @ 10:38 pm
Busted!!! Send the cops.
Posted Mon 06 May 13 @ 11:16 pm
Does your powered bass speaker have an xlr connection and what is the model and make in order to help you make a proper connection into your existing systen setup?
Posted Tue 07 May 13 @ 9:58 pm
