Mapping question, Is there anyway to map my Mic rotary volume contral on my Hercules 4-Mix controller to control the song key +/- ?
And if there is, what would be the proper script to use?
Thanks
Thanks
Posted Sat 04 May 13 @ 1:27 pm
If the knob sends midi, then you open up the mapper on the config menu and and hit the top right button and twist the knob. Then click the button below and click on the key knob on your skin. Should be all set. Not sure about your controller though. Might be hardware control only for that knob.
Posted Sat 04 May 13 @ 4:45 pm
If it works, I think it will control the active deck only though.
Posted Sat 04 May 13 @ 4:46 pm
Thanks, will try this, I just mapped some keyboard keys to get this done for now though..
Posted Sun 05 May 13 @ 12:58 pm
