Hi, Gang,
I have a weekly thing playing for an online radio station, and would like to record the set to publish online afterwards.
Can I record my sets while broadcasting online from within VDJ, or is it something I must do externally with something like Audacity?
Thanks much,
Ta
Mike
Thanks much,
Ta
Mike
Posted Sat 04 May 13 @ 1:01 am
You cannot record and broadcast currently.
I had a radio show for 2 years and used BUTT (http://butt.sourceforge.net) to record all my shows.
Just select the correct soundcard and away you go.
You can use BUTT to broadcast, but you loose the ability to send the title and artist with the stream.
My only advice: start BUTT before you start broadcasting. You can always trim in Audacity after.
Cheers,
Roy
Cheers,
Roy
Posted Sat 04 May 13 @ 1:57 am
Thank you!
Mike
Mike
Posted Sun 05 May 13 @ 2:07 am
