I'm still not quite sure I understand this timecode thing and the differences between equipment that needs and doesn't need timecode disks setup to control the software running on your pc.
I'm new to this (have pro 8) and was fortunate enough to have someone give me their Audio 8 DJ sound card which I was able to setup pretty easily and am getting a bit more comfortble with software learning how beatmatch, transition from songs, loops and some other stuff. Now I am interested in buying a controller because I detest using my mouse :P
if i'm willing to spend up to about $300 to physically control two decks what should I buy?
Posted Fri 26 Apr 13 @ 11:25 pm
Purchase virtual dj first, then a controller!
Posted Sat 27 Apr 13 @ 3:34 am
I disagree... buy a controller that sells with VDJ LE then get a discount on upgrading to Pro if you ever want to use timecode/video/better effects.
Timecode is a way of utilising older dj equipment that has been around prior to software and midi controllers taking over. Unless you are a scratch DJ or just like the feel of spinning on vinyl then your money is better spent on a midi controller.
The audio 8 is a great soundcard though and will serve you well for a few years to come. If I were you I'd get a mixtrack until you learn a bit more about what you want in a setup. If you like djing upgrade to VDJ Pro so you can utilise all of the features of the software and can easily upgrade any part of your setup.
Posted Sat 27 Apr 13 @ 4:03 am
Mixtrack doesen't come with VDJ Le anymore! In that budget he should get a Hercules RMX and immediately upgrade to VDJ pro. I think that'd be a great start For a beginner! But for timecode then yes you need VDJ Pro first ...
Posted Sat 27 Apr 13 @ 4:34 am
There's a new Mixtrack on the way - the Mixtrack Quad.
That does come with VDJ LE because it has a four channel mixer, and the Serato software doesn't offer four decks, so Numark have gone back to VDJ LE.
Posted Sat 27 Apr 13 @ 5:10 am
So since this comes with LE (I have home now idk why i said pro above..?) before I decide to buy pro I could easily set this up, learn for a period of time and upgrade in the future to pro with a discout later right?
http://www.amazon.com/Numark-Mixtrack-USB-Controller-Mac/dp/B003UVASTO/ref=sr_1_1?ie=UTF8&qid=1367079905&sr=8-1&keywords=mixtrack
or would it be worth it to spend a little extra on my first??
http://www.amazon.com/Numark-Mixtrack-Controller-Integrated-Interface/dp/B00466HLWO/ref=sr_1_2?ie=UTF8&qid=1367079905&sr=8-2&keywords=mixtrack
Posted Sat 27 Apr 13 @ 11:35 am
No - that's the original Mixtrack. No onboard audio.
Your second link is the Pro, which includes an audio interface.
However there's now a mk II version of both models (with & without sound).
The Mixtracks did used to ship with VDJ LE, but now they don't. Only the forthcoming Quad version will.
Posted Sat 27 Apr 13 @ 11:53 am
what does on board audio mean, cause I thought that was what my audio 8 dj already accomplished?
Posted Sat 27 Apr 13 @ 12:28 pm
On board audio means the unit has a sound card built in, so you wouldn't need the Audio 8.
Keith
Keith
Posted Sat 27 Apr 13 @ 12:31 pm
If I bought a controller that doesn't have onboard audio couldn't i just hook up both the audio 8 and the controller together??
And what other good beginner controllers are out there that come with LE (since quad isn't out yet...)
Posted Sat 27 Apr 13 @ 12:53 pm
Just search Google for DJ controllers and the phrase "includes virtual dj"...
Posted Sat 27 Apr 13 @ 1:47 pm
http://www.amazon.com/Hercules-4780638-DJ-Console-MK4/dp/B00371R8PO/ref=cm_cr_pr_product_top
Probably gonna get this then, comes with LE and has a soundcard, but what has better sound my audio 8 dj or this?
Posted Sat 27 Apr 13 @ 5:47 pm
Another nice controller that is not very expensive and fun to play with is The Pioneer DDJ ERGO. I have been using this controller and enjoy the lights for beat matching and the button configuration. Before purchasing look at reviews and see what button layout you prefer cause some controllers have a poor layout, too bulky, small jog wheels, or are just have a cheap plastic feel to the buttons.
Wish you the best...
Posted Sat 27 Apr 13 @ 11:35 pm
sorry typo expensive should be (in-expensive)
Posted Sat 27 Apr 13 @ 11:36 pm
$400 is inexpensive....?
Posted Sun 28 Apr 13 @ 1:57 am
the audio 8 is a much better soundcard, they really aren't comparable.
To use the audio 8 you need VDJ Pro.. What I was saying is that you should buy an LE controller to get a discount op upgrading it means you will get a controller for free when you factor in the full purchase price of VDJ Pro eg.
used never upgraded Mixtrack Pro off ebay $150
upgrade discount for MTP $150
VDJ pro full price $300
you still get the full version that can utilise the audio 8 and you get something to play on until you upgrade to something more serious.
Posted Sun 28 Apr 13 @ 2:27 am
