hello, i have a big problem. i unplugged my hurculies rmx2 to build a shelf for it, took it to a friends now i cant get power to it. tried unpugging it and restarting laptop and nothing. im getting worried my thought is ( i know nothing of inside controllers) is that it has fuses and i blew one but thats probly not the case. does anyone know what to do couse i need it working fast
Posted Sat 20 Apr 13 @ 1:31 pm
Hercules RMX2 require both the USB and Power Plug to work. If it don't return and replace it. The warranty is one year and it has not been on the market that long. Go to: www.hercules.com
Posted Wed 19 Jun 13 @ 2:57 pm
I am using a Hercules console RMX with Virtual DJ and I have 2 Stanton CD players. The CD players are connected directly to the Hercules mixer. My problem is the Hercules mixer at times loses the connection to the CD players. For example: I will be playing a song on the left CD player and once I fade over to the second player at times the mixer will lose connection to the first CD player by me selecting another song or by using the backspin affect. It does not happens at worried times so i can't really figure out why it does it. I can simply reconnect by going into the settings but when reconnecting you get a pause of sound for a second which when people are on the dance floor is not good for that pause. Can anyone tell me why at times I lose connection with the CD players and provide a solution.
Thanks fellow DJ's......
Posted Fri 21 Jun 13 @ 1:31 pm
Raider please don't hijack someone else's thread, you have already opened a thread of your own on the subject please be patient and await a reply there.
Posted Fri 21 Jun 13 @ 2:07 pm
@Raiders155
Which RMX do you have, and what are your computer specs?
I see you started a new thread, so if it's Not a RMX2, Then do not post here...
Posted Fri 21 Jun 13 @ 3:10 pm
