im using the hurculies rmx2 and the loop pads... not sure but i hit pad 1 and then have to hit pad 2 (otherwise it wont loop) and then its on a loop of 2. i want it to start on a loop of 4 or be able to start on any number loop i momentarily need is this possible? i use a mouse to loop but with some of the skins this is getting harder to do. with it starting on a loop of 2 all the time i have to quickly hit it to 4 and as quick as i get you still hear its a loop of 2.
Posted Mon 08 Apr 13 @ 11:18 pm
If you look at the MAPPER tab in the configuration menu of VDJ, you'll notice that the LOOP pads are assigned in the following way:
PAD 1: Loop In
PAD 2: Loop Out
PAD3: Loop_half
PAD 4: Loop_double
Using PAD 1 and 2, you can actually set any loop size.
- First set the In point,
- count the exact length,
- then set your loop out point.
PAD 1: Loop In
PAD 2: Loop Out
PAD3: Loop_half
PAD 4: Loop_double
Posted Tue 09 Apr 13 @ 7:44 am
