Can someone please help? I have been having problems here and there with my NS6 off and on. Just when I think I solved one problem, another one pop up. When I DJing, I keep hearing a "popping" noise through the speakers and headphones. Finally after about 2 hours of playing non-stop then the popping sounds gets worse then my software begins to stall. CAN SOMEONE PLEASE HELP ME WITH THIS ISSUE? I'm constantly spending DAYS/HOURS practicing at home so I can get all the kinks out before I get to a gig. I don't want any of these issues to pop up while I'm at a PAID gig. You know that won't look pretty. HELLLLLLLLLLLLLPPPPPPPPPPPPPPPPPPPPPPPPPPPP
Posted Fri 05 Apr 13 @ 8:56 pm
I had the same issue, but found a setting that has gotten rid of it... Go into your config, Sound Setup, and click on the ASIO config button... change the setting to 512 and apply. This gets rid of it for me.
Posted Sat 06 Apr 13 @ 7:27 am
I heard a white noise and light clicks with RCA to XLR NS6 to powered SRM450 but its only audible with no music and I didn't hear anything through the headphones. I tried changing to 512 and its gone, but your problem seems much worse.
Can you share your exact set up, pc & settings?
Posted Sat 06 Apr 13 @ 3:32 pm
Turn of the Master Tempo on ns6... and let me know if it works for you ...
Posted Sat 06 Apr 13 @ 4:42 pm
