before on 7.3 it worked now with 7.4 problems i have to use 2 souncard setup when i just used controller before no sound with old setup and new skins do i need to upgrade from 10.6.8? i'm a pro user
Posted Tue 02 Apr 13 @ 1:52 pm
Can you explain a little bit more detailed what the problem is?
Is there a error message?
Normaly the setting for the DJC is:
Inputs: None
Outputs: Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
Sound card: 4 out card -> Choose the DJC.4 sound card in the drop-down list.
Inputs: None
Posted Thu 04 Apr 13 @ 3:07 am
