Since you've been using VirtualDJ, what are the features you enjoy the most about it??? How has it helped your skill set???
As for me, I love the Loop feature the most, because I remember back in the days, most songs didn't have a instrumental, so we had to store 8 second samples that wasn't always easy to do, because you had to be perfect on the timing in order to get the perfect loop for the perfect sound. Especially now with all the extended versions, you can get up to a 32 count clean loop which was unheard of before the digital era!
I applaud VirtualDJ for this reason and so many more when it comes to the needs of allowing our creativity to flourish as DJ's!
Posted Fri 29 Mar 13 @ 7:58 am
Auto loop and user programmable midi mapping. If only I had this tech in the early nineties!
Posted Fri 29 Mar 13 @ 8:05 am
Gotta agree with Keith.... auto loop has saved my a$$ more times than I care to count
Posted Fri 29 Mar 13 @ 12:13 pm
Me? Used to be the SYNC button. Since getting my MTP and learning to beatmatch properly now though, its loops. Much fun to be had...
Ta
Mike
Ta
Mike
Posted Sat 30 Mar 13 @ 9:20 am
