I just purchsed an Asus G73JH with the following specs:
1.6 GHz Intel Core i7
· 8 GB DDR3 SDRAM
· 500 GB Serial ATA
· Windows 7 Home Premium
After loading VDJ Pro 7...one of my Numarks started playing fast(they one slated as my "B" deck). My sound Setup is as follows:
External Mixer
ASIO
Now because this controller is specifically designed to work with Serato Itch...I tried it and they both worked fine. I prefer VDJ Pro 7 over Itch. So is ther something else I have to check?
· 8 GB DDR3 SDRAM
· 500 GB Serial ATA
External Mixer
ASIO
Posted Tue 26 Mar 13 @ 1:50 pm
Press the master button on your slave deck (Deck B) to unlit master then it should play as normal.
Posted Tue 26 Mar 13 @ 4:05 pm
