What is your Operating System ? Do you see the files for the Launchpad in Devices and Mappers folders ?
Posted Tue 26 Nov 13 @ 3:27 pm
hello guys, i have the launchpad s, Ive downloaded the mapper for the Launchpad S but VDJ still will not recognize it. Is there something else I need to do?, i can see in Mappers folder, and Device folder , but when i open the vdj, config, mappers, i can see pioneer ddi sx,, simple midi wrapper ,and keyboard , if i check all devices connected and not connected i can found novation launchpad s . if someone can help me , thanks so much
Posted Sat 28 Dec 13 @ 11:50 am
You should send a PM to superaceman - possibly your device ID is different.
Posted Sat 28 Dec 13 @ 12:03 pm
I am on a MacBook Pro using Virtual Dj Pro 7.4 on an American Audio VMS4.1 trying to use the Novation LaunchPAD S I have downloaded, installed, deleted, reinstalled, google'd, youtube'd and still no luck at getting the LaunchPAD S to work PLEEEEEESE HEEEELLLLLLLP!!!
Posted Wed 12 Feb 14 @ 9:03 pm
What seems to be the problem (other than just saying "it doesn't work")?
Posted Thu 13 Feb 14 @ 4:54 am
Do you see the device in Config->Mappers tab by its name or as Simple Midi ?
Have you followed the instructions from here ..http://www.virtualdj.com/wiki/How%20do%20I%20install%20a%20custom%20mapper.html ?
Posted Thu 13 Feb 14 @ 5:28 pm
I've downloaded and installed everything I can find here and nothing it won't recognize any of the mappers looks like I'll have to create my own :-( sooooo don't want to do that lol
Posted Thu 13 Feb 14 @ 10:37 pm
Simple midi
yup followed the directions
Posted Thu 13 Feb 14 @ 10:43 pm
Can you see how the device is detected (named) ?
Goto Applications-->Utilities-->Audio Midi Setup
From the top menu choose Window-->Show Midi Window
We will need the exact name (case sensitive) of the Launchpad device
If not sure, post a screenshot of that window
thanks
thanks
Posted Thu 13 Feb 14 @ 11:46 pm
thanks
thanks
Launchpad S
Posted Fri 14 Feb 14 @ 5:57 pm
Ok, open the definition file with Text Editor (it should be in VirtualDJ/Devices folder ) and add ..
macdrivername="Launchpad S" in the 2nd line of the file.
So it should look like...
<?xml version="1.0" encoding="UTF-8"?>
<device ............ type="MIDI" decks="1" vid="0x1235" pid="0x0020" macdrivername="Launchpad S" >
Make sure VirtualDJ Home folder is the one you have the files. /Documents or /Library .. If you are not sure, add the files to both folders.
Posted Fri 14 Feb 14 @ 6:14 pm
ok maybe I'm being a complete noob at this but I still can't get it right is it ok if I PM you what I'm Seeing ?
Posted Fri 14 Feb 14 @ 7:12 pm
I watched what was done and yea no way my lil experience could have figured this out thanks for the great help djdad you just saved the launchpad s from being returned lol lifesaver!!!
Posted Fri 14 Feb 14 @ 9:31 pm
AMIGOS TENGO EL LAUNCHPAD S COMPRADO EN TIENDA Y AUN NO PUEDO OBTENER EL MAPPER PARA VDJ ALGUIEN QUE ME LO FACILITE PLEASE ? !
Posted Tue 18 Mar 14 @ 3:12 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
NOTE: You need to be a registered licensed user of the full VirtualDJ Professional to be able to download custom mappers and/or use other MIDI controllers besides your Beatmix. VirtualDJ LE for Beatmix will only work with that controller (Except during the 20 day trial of the full Pro.) You can upgrade to the full Pro at a discount by going to http://www.virtualdj.com/buy/index.html
Posted Tue 18 Mar 14 @ 3:28 pm
OK THANK YOU MEN BLESS
Posted Tue 18 Mar 14 @ 5:14 pm
HELP NEEDED
Hi everybody
Plugged my launchpad S in and the keys are working.
But I see no lights.
Tried it with ableton - there the lights are working.
I have a 7.4 professional VDJ
After installing the plugin i find "devices: LaunchPad S OPD device.xml"
and "Mappers: Launchpad S OPD Mapping.xml"
The data comes from Launchpad ---> VDJ
But the other direction seems to be broken.
So no lights are on, instead of one: If I press the "session"-button it lights.
Any help is very welcome
Thanks
Svenino
Hi everybody
Thanks
Svenino
Posted Tue 25 Mar 14 @ 10:54 am
If I use the old Version "install_Novation_Launchpad" (without "S")
and change the ID from pid="0x000E to pid="0x0020
the lights are ON!!!
But how about the new version?
Posted Tue 25 Mar 14 @ 7:59 pm
So the original Launchpad OPD mapper works if you change the pid?
Posted Tue 25 Mar 14 @ 8:31 pm
yes it works, but the new version of Your plugin doesn´t.
And the Beatgrid and the levelmeters are really amazing, would love to have them.
And the colors are to handle much easier wirh the new one.
There must be some problem with the definition-file?
Thank You
Thank You
Posted Wed 26 Mar 14 @ 7:49 am
