Forum: VirtualDJ Skins
Topic: Skin Pioneer CDJ2000 NEXUS + DJM900 NEXUS - Page: 3
i cant download skins because am not licence registered,what must i do to be registered for licence
Do i have to download a "slip mode" effect in order to work the slip function?
no, it's integrate in the last Virtual DJ 7.4 pro version
how to download
Very nice skin!
Thanks !!
how can we register as a license user?
www.virtualdj.com/buy/index.html
hello guys
I really need skin pioneer CDJ2000 NEXUS but um not able to download them what should i do
hi i dont see de pad buttens on the right of my screen when i select the rmx skin
do you have any idee/ tips?
And why can i set the effects butten on the master why only on ch 1 or ch2 of ch3 or ch4 ?
greetz arnaud from NL
i have insall the 2 versions and i start up just a view minuts ago to check it and when i select de rmx version i dond get the pads see first image
en now when i select witout vdj says :
Yesterday I could the skin (cdj200 and djm900 without RMX) do use
i think this image is beter
gr arnaud
with english text
greetz arnaud
there I do not know what happens ! Never heard of such problems...
What version of VDJ did you have ?
hi i have vdj 7
I have also been the software and everything (skins maps and stuff) removed and then reinstalled, unfortunately without results.
maybe you have an older version of the skin. Have you downloaded the latest ? Because it was often been corrected.
i downloaded the skin this week..
arnaud
67%
