Is anyone having a crackling sound with MC6000. I have noticed a definite difference between internal sound card and the ASIO of the 600
0. Please comment with any fix you have found. Thanks for reading.
Posted Mon 25 Feb 13 @ 12:24 am
It's hit and miss to be honest. Some people get them to work but you have to play around with the latency settings. If you don't scratch then just use the WDM drivers instead. It's to do with the 44.1 to 48khz conversion in VDJ. Hopefully be fixed in version 8.
You can also try Config > Performances and change 48kHz conversion to Quality Resampling.
Please also see here: https://virtualdj.com/forums/167783/General_Discussion/MC6000_In_ASIO_Mode_(Final_word).html
Keith
Keith
Posted Mon 25 Feb 13 @ 1:56 am
Keith. Thank you for the help. I will try these fixes. I do not do a lot of scratching, but I don't want to be limited. I hope this is a fix in version 8.
Posted Mon 25 Feb 13 @ 4:49 pm
