Hi guys, I'm having an eerie problem with my midi controller's (Reloop Mixage) Crossfader. When I bring it to the left, it sometimes doesn't goto 0%, I can only push it to 1-2%. This is a BIG problem since i have my crossfader set to scratch mode, meaning even 1% on the crossfader means you can hear 100% of the right side. I tried reseting the native mapping of my controller but it still doesn't work.
So could anyone help me map my crossfader so that even when the crossfader is mostly to the left or right (1-5% left), the sound is cut off? Basically making the cut off of the scratch crossfader in a shorter spectrum.
It would be very much appreciated, as I have a DJing contest early next month!
Thanks in advance
Thanks in advance
Posted Thu 21 Feb 13 @ 8:43 pm
What I'm going for in terms of code is along the lines of: If Crossfader ' less than -95%' Then deck 2 volume=0%
I just dont know the VDJ scripting very well ;^^
Posted Thu 21 Feb 13 @ 11:39 pm
param_smaller 5% ? crossfader 0% : param_greater 95% ? crossfader 100% : param_multiply 110% & crossfader
or maybe something like this
param_smaller 5% ? crossfader 0% : param_add 5% & param_multiply 110% & crossfader
not sure if it will work tbh... you are probably better off opening your mixage and cleaning and lubing the crossfader as they are pretty strong in the digital jockey 2 that I have and I can't imagine it wearing out very easily, even with heavy scratching.
Posted Fri 22 Feb 13 @ 12:35 am
Thanks for your response! I'll try your code out first and then maybe open up the mixage as a last resort
I should place this code after 'crossfader_curve' right?
Posted Fri 22 Feb 13 @ 12:41 am
there is two to try and no put that on the actual crossfader
Posted Fri 22 Feb 13 @ 12:44 am
Posted Fri 22 Feb 13 @ 5:58 am
