I'd like to buy your software, but the mapping for my console (dj tech dj for all) is missing. Since it is the same for DJ-Tech My Scratch, I wanted to know if it was possible to import that mapping and use it on my console. Thanks in advance
Posted Mon 18 Feb 13 @ 8:06 am
In my opinion it should be possible with a little hack.
I don't know if the midi signals of the my scratch and dj for all are exactly the same but if you select the my scratch mapping, which is natively supported, you should be able to select the function and use the "key learn" to let VDJ know, which button is responsible the action at present.
Just save it to your disk and that's it - ok you have to press or move each slider or button at least once. :D
Maybe it's easier to create a custom mapping on your own.
Posted Mon 18 Feb 13 @ 12:26 pm
