Hi there,
My the right volume fader on my mixtrack is glitching out and is no longer usable.
I was wondering if anyone could help me with some mapping script that would allow me to use the master fader (middle one) as my right side deck volume fader (I am using a 4 deck mapping) whilst still keeping the left volume fader mapped to the left volume fader in the software.
I have got a test for VDJ radio tomorrow so a quick answer would be forever appreciated.
Cheers,
Keep Kalm
Cheers,
Keep Kalm
Posted Sun 17 Feb 13 @ 1:28 am
I think it would have to be on a shift because the master isn't on a left deck/right deck status............. so try,
"var 'shift' ? deck 4 volume : deck 2 volume"
Hope that helps and good luck with your test, Im sure youll do fine.
Posted Sun 17 Feb 13 @ 3:16 am
Cheers heaps Huey!
You are a gentleman and a scholar :D
Keep Kalm
Keep Kalm
Posted Mon 18 Feb 13 @ 3:49 am
