Hello guys, can you please tell me what settings to choose in Virtual DJ?cause when I play music on it, the sound quality worsens..
Posted Fri 08 Feb 13 @ 8:47 pm
What sound card are you using? Are all files the same bit rate, or do they vary, and what are they? What do you mean by worsen?
Posted Fri 08 Feb 13 @ 9:47 pm
have you updated your computer? Do you have the newest drivers for the sound card? Have you updated ditect x and java and everything including windows?
Posted Fri 08 Feb 13 @ 10:34 pm
i have a built in sound card of mixtrack pro.
Posted Fri 08 Feb 13 @ 10:47 pm
Take a read here..
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Posted Fri 08 Feb 13 @ 11:00 pm
I modified the title of this post, so a Mixtrack Pro user can see, and offer you help.
Posted Fri 08 Feb 13 @ 11:32 pm
The Sound Only gets worse when you have Usb drop outs. You may have to tweak up your computer for better peformance.
Posted Fri 08 Feb 13 @ 11:39 pm
Yep, Take a look here to solve your problem https://virtualdj.com/forums/105257/PC_Version_Technical_Support/_DPC_Latency_Checker_(_THESYCON)_Helped_Me_Fix_My_Audio_Problems___.html
Posted Sat 09 Feb 13 @ 3:38 am
Make sure that power saving is not enabled on your USB ports in Windows device manager. On some computers this can cause problems due to your computer not giving sufficient power to the MIDI controller to operate correctly.
USB 3 ports can also cause problems with some hardware. Try using an external powered USB 2 hub.
Posted Sat 09 Feb 13 @ 2:06 pm
