I have a couple of moving heads, a couple of led light bars, several led pars and 4 scanners.
I have always let my lights do their own thing but with the moving heads, I want some control!
I am looking at the Elation DMX Operator and the Chauvet Obey 40.
I don't know which one is better.
Anyone know which is better and WHY?!? Anyone have any other suggestions?
I could use a little guidance. I need to get whatever i'm buying this weekend.
Thanks
Thanks
Posted Thu 07 Feb 13 @ 7:48 pm
the obey is easy to work with but your only touching the base of what your lights can do.. If you were in calgary I would give you mine as I have a usb to dmx from gracylighting china and can run anything.. google it.. worth the juice.
Posted Fri 08 Feb 13 @ 12:04 am
Just retired my Obey controller. Went with a Velleman VM116 and FreeStyler. Waaaayyyyyy more programable and less weight to carry around. Plus you can pass beats with SBDJ's plug in. Good luck !!!
Posted Fri 08 Feb 13 @ 2:20 am
