this is the skin i downloaded & loved it = https://virtualdj.com/addons/14974/Damian.html and this is the info from the orginal xml file = <textzone>
<size width="150" height="60"/>
<pos x="1290" y="30"/>
<text font="LCD" size="60" color="#ffa500" align="LEFT" weight="bold" format="%hour"/> and this is what i changed it to = format="%hour12"/> because i dont like the military time format. but my problem is when i was dj'ing last saturday after 12:00 midnight it showed 0000 ? but after 1am it showed the right tyme ? what did i do wrong and how can i fix it ?
Posted Wed 30 Jan 13 @ 1:52 pm
%hour12 is the correct syntax.
Posted Thu 31 Jan 13 @ 8:35 pm
then why after 12am it shows like this = 00:00 then after 1am it looked like this = 1:23am ? i want to fix the (00:00) problem
Posted Fri 01 Feb 13 @ 10:37 am
Here, try them all and see which one works for you.......
%fullhour : display the time in a hh:mm:ss format
%hour : display the time in a hh:mm format
%hour12 : display the time in a h:mm am/pm format
Good luck
Good luck
Posted Fri 01 Feb 13 @ 12:26 pm
thanx i fixed it
Posted Fri 01 Feb 13 @ 3:07 pm
