My VDJ Pro freezes after an hour or so of use with DDJ WEGO. I have the latest firmware and driver as specified on the Pioneer website. There are a number of posts on Pioneer support forum with same problem and there is no reply from Pioneer expert. I posted my problem on Pioneer Hardware section of our (VDJ) forum however it looks like Pioneer rep is not regularly answering user's posts. I would appreciate if somebody can help me solving the problem.
I have a very good laptop on which I have used VDJ Pro with Hercules RMX without any problem (Audio and Video)
Posted Wed 30 Jan 13 @ 1:39 pm
So, it's not your laptop or your software, but your controller. Call Pioneer. Forget the forum.
Posted Wed 30 Jan 13 @ 1:56 pm
Similar thing happened when the MC-6000 first came out and Denon fixed it with a firmware upgrade. Was related to the jog dial midi transmission.
Does the Wego freeze when doing anything particular or is it just random?
Keith
Keith
Posted Wed 30 Jan 13 @ 2:02 pm
I bought the WeGo and returned it the next day because it froze and crashed left right and center.
Posted Wed 30 Jan 13 @ 2:12 pm
The program freezes randomly and I would have returned the controller but I bought it in USA and brought it to India so I need a fix on whatever piece of junk I am stuck with. I would really appreciate if somebody can help me.
Posted Thu 31 Jan 13 @ 1:47 am
Weird. I used my Wego at a club last Saturday for 5 hours...no issues playing both audio and video. I am running Vdj 7.2.
Posted Thu 31 Jan 13 @ 10:35 pm
Could you yell us how you have your controller connected to your laptop? Also what version of Vdj are you running?
Like I said above, I am on 7.2.
I have my Wego plugged into a powered (AC electrical) usb hub then the hub into a port on my 6 year old laptop (win xp).
Posted Fri 01 Feb 13 @ 12:08 am
My controller is connected to USB port on the laptop. My laptop is Sony VAIO i5 6 GB RAM Win 7 Home Premium 64 bit op system.
I will try using powered hub and come back with results.
I am on VDJ 7.3. Does anybody think I should also go back to 7.2 (If yes - how do I get 7.2?)
Thanks for the help & suggestions JayMSY
Posted Fri 01 Feb 13 @ 2:18 am
on Pioneer website - http://pioneerdj.com/support/product.php?c=326&lang=en&p=DDJ-WeGO&t=faq
as stated in answer to Q 3, this unit is not supposed to function if connected to USB hub and yet you have it working on a USB hub - very strange.
Posted Fri 01 Feb 13 @ 9:21 am
Yeah I know. I had an audio glitch when mixing videos when I had the unit plugged directly into my 6 year old Dell laptop. I started contemplating switching to Mac hoping that would solve the problem.
As part of my troubleshooting I took the wego to my club...same audio glitches when mixing videos on their desktop xp machine. An idea hit me to try plugging the unit into the powered hub where I also plug in my hard drive...no audio glitches!!!! I went to best buy to buy 2 powered hubs. Tested it on the laptop..no glitches!! I can't recall the unit freezing either.
As far as 7.2 you would need to put in a ticket to support. It is always a good idea to download every version when it is released to a folder on your computer that way you will have previous versions to easily go back to.
Posted Fri 01 Feb 13 @ 11:19 pm
virtual dj meu nome e vinicius Comprei Uma DDJ Wego Eu Formatei o Meu Computador E Perdi o meu login e o software e meu codigo key não aceita em outra conta preciso muito da sua ajuda para recuperar meu email e a minha senha se quiserem mando minha key por email e voce recupera preciso de ajuda porque o software antigo tem muitos bugs que foram consertados. Obrigado
Posted Mon 08 Dec 14 @ 3:00 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum (Where available) to post in your own language.
These other language forums can be found at the bottom of the main forum topic list.
NOTE: For help with licensing or login account issues, please contact support.
Posted Tue 09 Dec 14 @ 2:00 pm
