Hi, I recently got a new controller, so I will no longer be needing my RMX. So I thought the thing to do would be sell it. Now the RMX comes with a copy of VDJ LE, and I used the serial from that to get a discounted price on VDJ. The question I am asking is can I sell that VDJ LE CD along with the RMX, or will it ruin my subscription to VDJ?
Thanks!
Harrison
Thanks!
Harrison
Posted Wed 30 Jan 13 @ 9:38 am
As you have registered that serial and used the discount the person who buys it from you will not be able to claim that or use the same LE serial number.
They will have to have a copy of Pro as serial numbers are non-transferable per the EULA.
Regards
Keith
Regards
Keith
Posted Wed 30 Jan 13 @ 9:43 am
Will they be able to use the VIRTUAL DJ LE CD, just not able to use the discount? Or can't use anything at all.
Posted Wed 30 Jan 13 @ 10:27 am
They can install VirtualDJ LE from the original CD, but they won't be entitled to any software updates or add-on downloads (These can't be used with LE anyway outside of the Pro trial.)
Unfortunately, once registered, serial numbers cannot be transferred to another user, especially when they have already been used to upgrade to the full VirtualDJ Pro at a discount (The serial forms part of your Pro license.)
Posted Wed 30 Jan 13 @ 8:31 pm
