Forum: Old versions
Topic: Virtual DJ LE Problems, etc.
To whom it may concern. I recently purchased the numark mix-track pros, which came with Virtual DJ LE. I just noticed this today that i couldnt find a way to load samples. I dont know if i just cant find it or if there is no way at all. i was just wondering if there was anyway to load samples onto virtual DJ LE because without it, my music doesnt sound right. Would i have to buy a different version of VDJ, or something along those lines, inorder to get these samples to load? If someone could get back to me on this that would be great. Thank you!
Posted Mon 28 Jan 13 @ 10:45 pm
VirtualDJ LE is free limited software and doesn't support loading/saving samples. It allows live temporary recording only (These will be lost when you exit the software.) Please see https://virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
If you wish to be able to load/save samples and much, much more, then you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE should entitle you to a discount providing that it is not second hand: https://virtualdj.com/buy/
