Hi!
I've been forced to start mapping my controller with VDJ Pro as it's not been picking it up properly,
So i'm pretty much there with most of the mapping but i cannot map my scroller knob on my controller?
I'm using a Reloop Beatmix,
Any help would be amazing!
Cheers
Cheers
Posted Mon 21 Jan 13 @ 12:52 pm
Also i've got my first birthday party gig coming up on Feb 16th,
I'm used to club stuff so i've no idea what to be playing! Any advice anyone could give/ send over their playlist for things like this would be brill
Posted Mon 21 Jan 13 @ 12:54 pm
The Reloop Beatmix is natively supported in the supplied LE version and in the latest version of VirtualDJ Pro so you do not need to map it yourself.
If you are using the Pro version instead of LE, please enter your Pro serial number in your user profile and download & install the latest 7.03 version from this website.
https://virtualdj.com/users/edit.html
Regards
Keith
Regards
Keith
Posted Mon 21 Jan 13 @ 1:17 pm
I have VDJ . I just bought Gemini Firstmix pro controller, i wanted to know if it cand be mapped to VDJ software cause the software that came with the controller dont have a place to enter my url, pass word, username and port number for streaming, any ideas.
[Sorry, posting E-mail addresses and other contact details is not permitted for unlicensed users - Please read the forum rules]
Posted Wed 03 Apr 13 @ 11:30 am
If it came with VirtualDJ LE included then this is free limited software and doesn't support broadcasting. Please see https://virtualdj.com/products/comparison.html
To be able to broadcast, use custom skins/mappings and much, much more, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/ - Your VirtualDJ LE should entitle you to a discount.
Posted Wed 03 Apr 13 @ 12:26 pm
