ok, so i got the numark idj3 and the virtual dj pro 7. i have recently purchased the m audio fast track pro sound card and have no idea how to connect the two ...can some one please help!!!!!!!!!!!!!ive tried everything from buying cables to amps receiver...someone please help!!!!!!!!!!
Posted Sun 20 Jan 13 @ 1:24 pm
First of all, read your instructions that came with the hardware, second Register your Virtual DJ 7 Pro software with Atomix on this web site, by registering, that ensures you to get tech support for free, as well as enabling you to download all future software updates at no charge and also free "add-on's" posted like skins & sound effects, ect.
Next: install your VDJ Pro software on your computer, then connect your hardware via USB cable and install the hardware drivers that came with the controller and sound card.
On the back of the sound card hardware you should have some RCA connectors, one set labeled "in" or "out", connect your "out" connectors Left/Right channel to your amplifier.
Start up your VDJ software and go to the configure tab and choose your hardware from the list, Virtual DJ Software will run through that setting, that should have you up and running.
Sincerely yours, Jeff
Posted Mon 21 Jan 13 @ 8:25 am
