Hellow,
Today i got my beatmix from Reloop but... i got 2 BIG PROBLEMS ! (Beginner)
Problem 1: I have no sound coming out my pc speakers or headphone when connecting beatmix !
Problem 2: Lost all my effects i had on VDJ pro: Delay, LFO, Echo v2, Cut, Beatbox fader, TK filter v2, Isolator etc,....
Thanks for help ! Really need it ...
Posted Tue 08 Jan 13 @ 2:12 pm
without having a beatmix im just guessing here.
on the controler what are the master out connectied to??
most new controllers require the maser out to be connectied to an amp/speaker system.
so try connecting to an amp or plug directly into ur pc speakers or alternatively connect it to ur pc line in
Posted Tue 08 Jan 13 @ 2:24 pm
For the sound its ok now ;-) had to go in VDJ setup. But how can i get all my effects back from VDJ pro ? Btw when you use echo on reloop beatmix how can you change delay ? tryed every button but it only affacts the volume of effects. >Thanks
Posted Tue 08 Jan 13 @ 2:54 pm
@Oblivioz,
You already have a thread running discussing this, please don't create another thread just to get answers quicker as it's against the forum rules.
I'm locking this one. Continue your discussion here: https://virtualdj.com/forums/173384/General_Discussion/Beginner__Starting_with_hardware_using_Virtual_Dj_Pro_Full.html
Keith
Keith
Posted Tue 08 Jan 13 @ 2:57 pm
