Sorry forum, I have seen a previous post on this script, but cannot find it now....I need the script to revert the crossfader to the original function (the the 7.5 release).....my prob is the fader doesn't fade the opposite track out until the fader is almost completely to the left or right position, instead of gradually fading to the other track as the fader was moved across....thank you
Posted Tue 08 Jan 13 @ 1:07 pm
You can change the crossfader curve in CONFIG -> Options
NOTE: If you are using a MIDI controller, then this might have a crossfader curve knob to set this.
Posted Tue 08 Jan 13 @ 1:16 pm
