Hi guys I poste before an no one replied. Maybe if I explain a little better I can get an answer. Does anyone know how to assign the controls from the xdj so that all the buttons work? The tempo works when I slide it on the console it also slides in the program. But that's pretty much it. I want to assign the cross fader and the levels can anyone help me please???
Posted Mon 31 Dec 12 @ 12:17 am
What sound settings are you using in config?
If you're using 'internal mixer' then the Aero controls should be assigned to the VDJ controls, because they're all MIDI mappable according to the Aero manual. I don't know how the mapping is assigned, but the Aero does have native support in VDJ now.
If you're using 'external mixer' mode then you don't need the controls on screen - you have a real mixer in front of you!
Posted Mon 31 Dec 12 @ 8:03 am
As groovindj asked, did you change the XDJ-AERO's mixer setting to PC? Page 26 of the XDJ-AERO manual - bottom of the left column.
By default (out of the box) it is set to XDJ-AERO which is to be used when NOT using DJ software.
You have to change it to [PC] mode to used with software like VirtualDJ.
Posted Mon 31 Dec 12 @ 9:35 am
hi guys thanks for your help. I don't know how to assign the mapping controls to virtual dj.. as far as the setting to the PC mode, how do i do that? I did what you mentioned above i took it out of the box and just connected directly to the usb...
Posted Mon 31 Dec 12 @ 2:28 pm
I gave you the page number in the manual for the XDJ-Aero -- it's on page 26.
After you set it to the correct mode, then all you have to do is run VirtualDJ and everything will work.
Posted Mon 31 Dec 12 @ 5:12 pm
Perfect that worked! I set it up as pc mixing mode and its compatible now. Thank you very much and happy new year gentlemen!!
Posted Tue 01 Jan 13 @ 9:10 pm
I use the XDJ- AERO and when i go to virtual dj config i can see 3 section on sound setup input ( i set it on none ) output ( i set it on external mixer ) and sound card ( i set it on asio driver ) but when i will connect it to xdj even i select XDJ-AERO on the control mixer mode, virtual dj send me not enough Chanel to connect . i try million times but still i couldn't connect my xdj to virtual dj please help me on this point...
Posted Mon 06 May 13 @ 8:52 am
I'm connecting my laptop with the virtual dj software to my Pioneer XDJ-AERO & trying to licence the software with my controllers serial number & keep getting invalid code message...how do I register the software with my device serial number?
Posted Sat 29 Oct 16 @ 10:17 am
Quick answer - you don't use your XDJ serial number to register Virtual DJ.
You need a Virtual DJ license (which is not a serial number).
Once you buy your license from here, it it linked to your forum account. You then log in to Virtual DJ using your forum name and password, and it will recognise that you have a license.
Posted Sat 29 Oct 16 @ 11:42 am
