Hello, first of all say that my writing in English is not very good as it is not my language.
P.D: I'm spanish
I have my mixer DJM 850K and want to use it with Virtual DJ for radio broadcast, then that low volume from my virtual DJM I can not lower the volume. I have understood that it is configuration problem "mapped" Anyone know how to set it right please? It's urgent.
Thanks in advance
P.D: I'm spanish
Thanks in advance
Posted Fri 28 Dec 12 @ 1:47 pm
Please help me, I can map out my How mixer with virtual dj? :S
Posted Sat 29 Dec 12 @ 8:53 am
The LE version that you appear to be using only supports the controller it was bundled with. You would need to purchase the Pro version to use other controllers. The only other way to do this is to mix the channels in analog instead of controlling the software.
Posted Sat 29 Dec 12 @ 8:57 am
Oh okay, and can you tell me how to do please!?
Posted Sat 29 Dec 12 @ 12:52 pm
Go to here - https://virtualdj.com/buy/
In the middle of the page, enter your LE serial number and click 'Continue'.
Then finish the BUY page and get the PRO version at your upgraded price.
Posted Sat 29 Dec 12 @ 2:06 pm
OMG! Very expensive: S I just want to use it to make online radio happens I have to do from my DJM that grabs my Hercules no good my Shure too loose and you hear, buy virtual dj for that alone and not expensive tant mereze the penis : (Here in Spain the thing is not to spend money lol. Good luck and thanks!'m very angry and sad
Posted Sat 29 Dec 12 @ 3:42 pm
Then I guess you get what you pay for. So I guess you could purchase Broadcaster Edition of VDJ and just use keyboard and mouse for broadcasting online.
Posted Sat 29 Dec 12 @ 4:14 pm
I always did my online radio and a microphone hercules mk4 bad and very cheap but sounds good. Now I buy a Shure PG57 but my HERCULES MK4 is not enough good to feel good high, then from there to my problem biene mappear my DJM 850K and having input and output XLC and listen a lot better, and has better integrated sound card. Go problem! No you do haha took 3 days looking like, google, google, youtube, youtube and nothing I see the only solution is MONEY! clear this ..
I use Virtual PRO FULL 7.0.5
Posted Sat 29 Dec 12 @ 5:32 pm
You are using an illegal version if you are using VirtualDJ Pro 7.0.5.
Also, there is no mapper for the DJM-850. It is an external mixer with some MIDI capabilities that you can map yourself using the SimpleMIDI mapper.
And do not send me a private message asking for me to send you stuff. I am definitely the wrong person to be asking that type of question.
You should really get your priorities in order if this is the type of business you want to get into. Using illegal software and music is not an exceptable way of acting if you want to make it in this business.
Posted Sat 29 Dec 12 @ 6:49 pm
Okay so if I buy this: http://es.virtualdj.com/buy/index.html
Will I be able to download the mapping DJM-850-K that are already here, or do the maping to my taste? Really sure? I hope it will serve me for 248 € >. <
Oh, What buy A or B?
Posted Sun 30 Dec 12 @ 7:09 am
It's your choice. Spend $329 or $299...........or only $199 for an upgrade. You decide!
It's funny - you have a DJM850 but think that Virtual DJ software is expensive. :-)
Posted Sun 30 Dec 12 @ 7:21 am
Go for the upgrade of 199 as its the cheapest and sorry about groovindj, but you will get used to him coming over sarcastic and condescending all the time :-).
One thing I can say though you will not be disappointed by upgrading (free upgrades / effects / skins / mappers and more), hope to see you on the PRO side soon.
Posted Sun 30 Dec 12 @ 7:44 am
I see expensive simply because it would give little use, because I just want the mapping to radio .. lol
Thanks guys and HAPPY NEW YEAR! :DDDDD
Posted Sun 30 Dec 12 @ 6:02 pm
