Topic: Effect Problem
i have recently bought a pioneer DDJ WEGO controller with Virtual DJ LE, i plugged i all in and everything is running fine except for the effects, none of them work except for flanger. i have read many other discussions with similar problems and nothing has worked for me. i and also working on a macbook pro, can someone please help me
thankyou :)
Posted Fri 28 Dec 12 @ 1:20 am
Hi, not sure what the problem is, but if you've installed the software and the rest of it works, there's no easy answer I can think of.
I think you need to contact support
https://virtualdj.com/contact/
Nevermind your on a Mac........
On a Mac?
groovindj wrote :
On a Mac?
yeah on a mac !
I was questioning beatbreaker's reply, which was PC specific (before he edited it!).
Do the effects work OK when you use them with a mouse or from the keyboard?
haha oh sorry !
um no the effects dont work at all, only Flanger and Phaser work
I have this problem too. Very Frustrating
