Hi guys,
I have been using for several years - initially with a Mk2 console, then later an RMX.
I am tired of the limitations of the RMX - mostly not being able to scratch. I would like to add a pair of Pioneer CDJ200's and VDJ Pro to my setup. Will this allow me to scratch as one would with turntables?
Would I be better off just buying a new Vestax VCI300 instead?
Posted Thu 27 Dec 12 @ 7:07 am
Either will be fine, just get a better sound card than an RMX controller.
Posted Thu 27 Dec 12 @ 1:37 pm
If scratching is the only issue you have with the RMX, then you could also consider the new RMX2 or 4-Mx, both of which have pressure-sensitive jogwheels.
Posted Fri 28 Dec 12 @ 7:27 am
