Hello,
I'm new with VDJ, I come from Serato and I thought I'd give VDJ a try, liking it a LOT so far.
So I'm starting to map my midi controller (a Novation Twitch). Everything is going well except for a few advanced stuff.
— I don't manage to map those endless rotary knobs. I mapped the pitch of Deck 1 to a rotary on my Twitch but when I turn that knob the pitch just goes from max to minimum. I couldn't find a value field in the midi editor.
— I'd like to map the touch strip of my Twitch controller (I would like to be able to nudge the audio with this strip) but same kind of problem. Any idea how to map that?
— I can't figurate how to do so that when I keep the "hot cues" button pressed on my Twitch and then hit a pad, it will delete this specific hot cue.
— Also I'd like to know how to do so that the LEDS respond to what's going on in VDJ, for example it would be nice if the LEDS could display is there's a hot cue recorded or not on the pads.
I realize it's a lot of questions, I'd be happy to start with, if someone help me to map those rotary ;)
Thank you for any help.
Posted Tue 18 Dec 12 @ 3:23 pm
if you want to use encoders or LED's you will need to create a definition file for your hardware, information can be found at the following link.
https://virtualdj.com/wiki/ControllerDefinitionMIDI.html
Posted Tue 18 Dec 12 @ 10:40 pm
You don't need to map the Twitch - It's already natively supported with fully working LED's, touch strip, etc. in the latest version of the full VirtualDJ Pro: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
Please download the latest Home Free to try it out before purchasing: https://virtualdj.com/download/free.html
Then if you like VirtualDJ, please support the software and its future development by purchasing it from https://virtualdj.com/buy/
NOTE: Using simple MIDI wrapper, you won't be able to map LED's or some of the advanced MIDI features that the Twitch uses. Simple MIDI wrapper only supports very basic MIDI mapping.
Posted Wed 19 Dec 12 @ 5:25 am
